ECU swap = car not starting
hi, i've swapped everything needed to swap D16y8 with B16a2 including obdI ecu with a obdII ecu and the full wiring harness.
However when the obdII ecu is plugged in the car will not start, im guessin this is because the key is coded with the original ecu, is there anyway around this?
any info appreciated, thanks.
