ECU Q
ECU Q
Hey i have a chipped p28 ecu.I just received a chip with basemaps froma P08 for my JDm D15B but what chip am i suppose to remove? sorry for the noobness but i have no clue A pic would be nice
cute little bastard
Re: ECU Q (mortificationrock)
The one that says SST in the picture. Should be located in the bottom right area when the words are rightside up that is.
Better picture
Take a flathead screwdriver and VERY CAREFULLY pry it up.
Better picture
Re: ECU Q (MADEINIRAQ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MADEINIRAQ »</TD></TR><TR><TD CLASS="quote">if you have a ZIF socket(blue in the pic).. turn the lever. don't pry. </TD></TR></TABLE> What? What do you mean?Sorry but I'm pretty noob at ecu's.Turn lever don't pry,wtf is pry anyways?
on a normal socket (the part that holds the chip) you have to gently lift the chip out with a small screw driver or chip removal tool because you are sliding the pins out of the socket that is trying to hold the chip in. (pry = move something with force)
in that pic, the blue piece has the grey arm on the right hand side, the top of it is lifted/rotated to spread the clamping connections apart so the chip slides out with little to zero force. (this type of socket is called a ZIF - zero insertion force)
carlip
07-11-2006 12:21 PM
eg6turb0
09-05-2004 03:39 PM
