ECU harness gone to HELLLLLL!!!!!!!!!!!!!!!
HELP! ecu was cut from harness at the plugs a while back. I tried to re-wire the harness the cell light is solid while checking it and the car does not run worth **** hella rich and boggy. started to get a harness out of another car...... HHEEEEEEEEEEEEEElllllllllllllll no! wasnt happening.
I guess my ? is what do i do now the ej is fucked!!!
Re: ECU harness gone to HELLLLLL!!!!!!!!!!!!!!! (mzboy)
the car was a wrecker and i gave up, Have to take all the dash and heater and **** what a pain...
the reason rewiring didnt work is because the resistance was changed in the wires
only thing you can do is swap in a harness
i no its a pain but if you ever want your car to run right again youll have to
Re: ECU harness gone to HELLLLLL!!!!!!!!!!!!!!! (EJ1Racing.tk)
Well the same thing happened to me in my Sol. I was removing the wiring for my ABS system and somewhere in the mix I messed up the harness. I was lucky and found one on ebay for $100.00 in perfect condition with the clips still intact. Your only other option is to go source another one.
Naudlee
17
08-14-2006 06:25 AM
Superhatch
07-10-2002 04:37 AM
