ebrake issue, with rear disc conversion
well, just need a quick answer from those who have done it. I've read as much as I could before I started this and I guess I missed a spot. Anyways, I have a 98 hatchback, and I purchased some 00 GSR rear brakes and trailing arms. Everything mounts up, all the lines are good, until I got to the ebrake. I tried to adjust it but it's super tight. My question is, which ebrake line do i have to get if i have to get any at all.
The 99-00 si ebrake line or the 00 gsr ebrake line? Thanks, sorry to bring this issue back up again, i just couldn't find a clear answer.
Re: ebrake issue, with rear disc conversion
yeah that's why i'm asking, car is in the air right now, it's all bled, everything works fine. might have to drive around without an ebrake until tuesday lol
yeah, that's what i keep reading. The si stuff will work but i have a gsr rear disc, not sure if it applies. I just took it for a test drive and man, i can't believe i didn't do it earlier, they stop awesome!! brake pedal doesn't feel bad at all, a little on the soft side but still firm. I didn't replace the prop valve, cause the part number is the same as the one for the si. And i figure, crap if the prop valve is the same, i didn't replace the MC either. Now just this ebrake problem, grrrr..... thanks again HT, i do appreciate the help!
hey curioso, i think i'm going to try the si ebrake cables. Can anybody confirm? if anybody has a part number for them, that would definately help.
right now i'm using the integra gsr ebrake cables and they are short.
I did the gsr swap on my eg. I used the cables from the eg si and it bolted straight up.Not sure if the ek hatch has a model with rear disc .but if it does all you need are the cables from the same type of car you have that has a rear disc.My gsr brakes were off a 99 gsr and it bolted on no problem.
blu3g
05-21-2007 09:24 AM
B96v6
02-28-2006 08:01 AM
