E-brake Help!
E-brake Help!
Ok I've got rear disc brakes on my EK civic from a GSR I need an E-brake cable. I've been told that a 2000 SI E-brake cable will work. Now I'm not sure what parts I need to order I have included a picture of what is left of my e-brake components. I know i will need 17 & 18 from the diagram, but will I need anything else? Can someone help me out and let me know what else I need to order.
Thanks
<FONT COLOR=""Red"">Here's what's left inside:</FONT>
<FONT COLOR=""Red"">Link to parts diagram:</FONT>
https://www.hondapartsdeals.co...B++26
Thanks
Re: E-brake Help! (Flash202)
That's a pretty crappy diagram.
http://www.slhondaparts.com/br...=true
You'll need 17 & 18 as well as 16, 19 and 20 for each side.
Re: E-brake Help! (AutoXer)
Thanks for the help man can any one else confirm this I just want to make sure I order everything I need. Also are 17 and 18 the regualr brake lines? Because I have brake lines I just need to connect the e-brake...
Modified by Flash202 at 12:20 PM 2/28/2006
For that ebrake cable conversion you can re-use everything from the EK except the cables themselves, just get SI cable and you're good to go.
Re: E-brake Help! (Stop the Beast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stop the Beast »</TD></TR><TR><TD CLASS="quote">For that ebrake cable conversion you can re-use everything from the EK except the cables themselves, just get SI cable and you're good to go.</TD></TR></TABLE>DO WHAT THIS GUY SAID
I no longer have any of the cabels from my EK that's why I have to order all new ones a lil help anyone? Should I just get everything pictured in the diagram?
Re: E-brake Help! (kaiba)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaiba »</TD></TR><TR><TD CLASS="quote">The end of the cable of both disc and drum are different.</TD></TR></TABLE>
Huh? All I'm trying to find out is what do I have to order to install a complete E-brake as of now I have NO E-BRAKE CABELS what so ever, if you look at my first post just look at the link to the diagram and tell me what I need to order, please.
Thanks
Modified by Flash202 at 9:23 AM 3/1/2006
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flash202 »</TD></TR><TR><TD CLASS="quote">Huh? All I'm trying to find out is what do I have to order to install a complete E-brake as of now I have NO E-BRAKE CABELS what so ever, if you look at my first post just look at the link to the diagram and tell me what I need to order, please.
Thanks
Modified by Flash202 at 9:23 AM 3/1/2006</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoXer »</TD></TR><TR><TD CLASS="quote">That's a pretty crappy diagram.
You'll need 17 & 18 as well as 16, 19 and 20 for each side.</TD></TR></TABLE>
Thanks
Im having the same problem for my swap except my discs were donated from a delsol. I still have all of my stock EG stuff what Cable would I need Teg or 99-00 Si????
My Problem...... https://honda-tech.com/zerothread?id=1594138
Trey
Suspension & Brakes
03-26-2010 10:37 PM
ExCon
09-22-2006 08:28 PM
