drum-to-disc conversion help
Re: drum-to-disc conversion help (ghettocivic94)
I also think crx si rear disc brakes will work too...correct me if Im wrong. If they do, Im willing to be they could be had for very cheap.
Re: (ghettocivic94)
sure they'll fit.
dang. who gave up the wrong info?!
YES THEY WILL FIT.
of course it depends on how many parts you plan on swapping. you can swap just the rear hubs or the entire trailing arms, whichever you consider easier.
YES THEY WILL FIT.
Yes they will work, you can put DA rears on an EG. Only problem i have with that is the fact that the parts just too old (worn bushings).
Re: drum-to-disc conversion help (redlinetuning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlinetuning »</TD></TR><TR><TD CLASS="quote">No.. the DA parts will not work into an EG, DC, nor EK. Only EFs and DA's are interchangeable. </TD></TR></TABLE> dude, I think you are wrong. Also, you better specify what parts you are taling about if you think they do NOT interchange. Of course the DA/EF rear disc swap is usable on EG's, DC's and EK's, but the other suspension parts (lca's, uca's, front knuckles, etc...) are NOT.
Re: drum-to-disc conversion help (owen_the_soyboy)
The DA brakes will 100% work on an EG... Or any other Honda til .00. We put a set of 91 GS rear discs on a friends 94 hatch and it was a direct swap. We kept his control arms, as well as the Toe link on the trailing arm. The trailing arms are the same dimension, its just other parts (mentioned) that have subtle differences.
ghettocivic94, go ahead and swap them. You will see first hand how easy and direct it is.
Re: drum-to-disc conversion help (hondahans)
well...i guess i have a weekend project...all i have to do now is go and get some new brake lines ...anything else i would need...maybe new pads too
racerx510
07-27-2010 01:35 PM
ZzZzz EH2
04-22-2004 10:45 PM
