Door Interior removal help PLEASE !!!
Okay I got everything off the hooks but stuck on the part where the window control is... How to get it off and unhooked??
This gold piece is stuck to the window handle..... HOW TO REMOVE??
Re: Door Interior removal help PLEASE !!! (EGB18hatch)
shop towel and use it like floss between the pannel and window know and pull up pin or small flat head or small needle nose plyers
easy, just install the door then make sure the metal ring is around the notch on your window crank. then guesstimate where you want the position of your crank to be at when the window is fully rolled up and just pop it on
B18cHatch06
07-18-2007 08:36 PM
Redline it.
07-02-2005 08:31 AM
Mentat Ghola
01-11-2003 04:47 PM
