Is the Dome light linked to the keyless entry/power locks.
Old 09-02-2013, 11:00 AM
Blazing angel's Avatar
Default Is the Dome light linked to the keyless entry/power locks.
1999 Honda Civic Special Edition Sedan
I am asking this because my dome light does not work when doors are opened, and my factory keyless is dead. The cabling between the doors and the fender were destroyed in the driver side fender, so I just ran my own cabling for my stereo.
Ever since the wiring harness was destroyed, the dome light never turned on again (when any door opened). I removed the keyless fuses too (to avoid a short circuit). Now, I'm running my own wires from the door actuators to a new remote starter I am installing to get it back. The alarm has domelight supervision, and I am wondering if it is possible to get it turn on when I unlock the car.
Does anyone know if this will work? And does anyone have a wiring diagram for the factory keyless? (So I can plug in the horn, parking lights, etc.)
The car does chime when I open the driver door with the key in the ignition.
Thanks in advance.
Old 09-02-2013, 03:29 PM
Default Re: Is the Dome light linked to the keyless entry/power locks.
anyone?
Old 09-02-2013, 06:12 PM
Technical Hero
HondaPartsHero's Avatar
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/diy-96-98-civic-dome-light-fix-after-installing-aftermarket-radio-2214962/
Old 09-03-2013, 01:09 PM
That isn t for a 99 right?
Old 09-04-2013, 07:42 AM
Anyone else have any input? Thanks again.
Old 09-04-2013, 07:54 AM
kyden's Avatar
fix your wiring. The dome light comes on when you unlock the car with keyless.
Old 09-09-2013, 07:51 PM
MY13CRV's Avatar
Check that door trigger pin to ensure the ground and hot is good (make sure the fuse is good).
ronaldrperez
02-23-2017 02:45 PM
jeff79
12-06-2008 07:45 PM
Kavehman
Audio / Security / Video
01-04-2006 03:24 AM
AznJammyJam
10-07-2004 01:51 AM
Quick Reply: Is the Dome light linked to the keyless entry/power locks.
