Does seafoam help take sludge away?
I'm about to change the oil in my civic and decided that maybe I should try a little seafoam in the oil a day before I change it. Questions is will it really work in taking some of the carbon and sludge buildup inside the head off and basically settle when I drain it into the oil pan? Has anyone had any experience with this or know's it will work good? I was thinking of taking a picture of inside of the head before and than a pic of it after to see the effects.
Re: (bsixteen)
Yeah, but nothing really about my question. I've used it before in my cars but i'm asking specifically if it will clean up the head any if I had it in there for a day.
Re: (Shaguar47)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shaguar47 »</TD></TR><TR><TD CLASS="quote">Yeah, but nothing really about my question. I've used it before in my cars but i'm asking specifically if it will clean up the head any if I had it in there for a day.</TD></TR></TABLE>
for the oil, ur susppose to put it in, drive for about 300-400 miles then change the oil.. it all should come out when u drain it. it does wonders. cleans out all the carbon on the values, and carbon in genral everywhere..
HT White Ops
Re: (ej1black)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej1black »</TD></TR><TR><TD CLASS="quote">
for the oil, ur susppose to put it in, drive for about 300-400 miles then change the oil.. it all should come out when u drain it. it does wonders. cleans out all the carbon on the values, and carbon in genral everywhere.. </TD></TR></TABLE>
No ....
When you Seafoam a Honda, you put 1/3 in the gas tank, 1/3 into the intake manifold through the brake booster hose, and 1/3 directly in the crankcase through the head. You drive at about 4000-4500 RPM's until it stops smoking. Then you come home and change your oil and sparkplugs.
300-400 miles with oil full of carbon ...
No ....
Ek Forever y0!
Re: (Eran)
Holy %#$^
Eran - 1,000,006
N00bies - 4
That's how I do seafoam, in 1/3's distributed among the fuel tank, crankcase and brake booster.
Holy %#$^
Eran - 1,000,006
N00bies - 4
U dont need to change the plugs......but seafoam reccomends 5oo miles of driving,I agree with changing oil asap,but u can keep the plugs unless they are fouling out.
Re: (Donkey85)
It'll get up to operating temp while you're running the seafoam through the brake booster.
I add 1/3 to the fuel, 1/3 into the crankcase and feed the rest through the brake booster. Once it's done I change the oil and plugs.
baphomet
09-22-2005 10:03 AM
