Does anyone know how to adjust doors.
Old 09-18-2003, 09:15 AM
93si's Avatar
Default Does anyone know how to adjust doors.
Driver side door hangs low, when I close the door the door moves up to set..Its there some adjustment that I need to make to hinges to fix this or do I need to bring it to a body shop?
Also my windows rattles when I open them and close the door with the windows open. How do I fix this, also windows open very slow, any advice on this? Can I get newer faster motors for it?
Old 09-18-2003, 09:25 AM
hayabusa160's Avatar
Default Re: Does anyone know how to adjust doors. (93si)
lube the window rails inside the door they will move faster then
Old 09-18-2003, 09:28 AM
allmotorEG-SI's Avatar
Default Re: Does anyone know how to adjust doors. (hayabusa160)
I think a bodyshop would have to fix your door. As far as I know there isn't anything to adjust. It could just be the metal is bent. Maybe there is something loose as well. But I really doubt you can "adjust" it to fix it.
Old 09-18-2003, 09:45 AM
93EH6
Guest
Posts: n/a
You can loosen the bolts the atachit to the car and the move it to where it needs to go then retighten them i had to do this to my sol when i painted it cause i took them off
Old 09-18-2003, 02:09 PM
93si's Avatar
thanks fellows, I'll try that
Old 09-18-2003, 10:01 PM
93EH6
Guest
Posts: n/a
Default Re: (93si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93si &raquo;</TD></TR><TR><TD CLASS="quote">thanks fellows, I'll try that </TD></TR></TABLE>
No Problem
Old 09-19-2003, 03:30 AM
underrated's Avatar
The way we align doors is to loosen the bolts holding the doors on,use a floor jack to jack up the door to the desired height, and tighten. We use to do these on low riders.
Old 09-19-2003, 04:10 AM
goodbyegti's Avatar
yeah good plan, i'll have to try that, my passenger side door is hanging a little low..
rayaman2
03-16-2011 11:36 AM
raphael
Paint and Body
11
11-08-2007 05:36 AM
H22a T13
08-31-2006 03:40 PM
lalaine17
05-04-2006 05:18 PM
Quick Reply: Does anyone know how to adjust doors.
