delsol/lsv swap is shaking
Old 02-20-2013, 06:45 PM
keith1993may's Avatar
Default delsol/lsv swap is shaking
delete fixed.
Old 02-20-2013, 07:05 PM
Emeraldbomber's Avatar
Default Re: delsol/lsv swap is shaking
Hows your diff bearings?
Old 02-20-2013, 08:54 PM
not sure.. im not the best mechanic but i just put a brand new tranny in the other day because my case was busted and couldnt hook the t bracket up. the new one has been rebuilt with b16 1st 2nd gsr 3rd and ls 4th n 5th. isnt the diff in the tranny?
Old 02-21-2013, 06:19 AM
delsolintegra's Avatar
i've seen that done. They weld about a 2 inch spacer to the bottom of the mount to reach the lower hanging manual transmission. I've seen where the lower control arm on that side has the bushing ruined. You might have to replace the LCA and then get a front end alignment.
Old 02-21-2013, 06:20 AM
kyden's Avatar
does the engine sit level? it could be a huge reason for the axle popping out.
Old 02-21-2013, 07:47 AM
thanks delsolintegra ill go check the lca on that side. well it pretty much sits level. whoever did the mount did a pretty good job but this is also my 1st DOHC.so im still learning. ill go look at how it sits. but would that cause shaking?
Old 02-21-2013, 08:56 AM
S2BumpsticksGSR's Avatar
Also have a good look @ midshaft bushing/bearing(bolts to back of block w/3 bolts). When these are bad feels similar to unbalanced wheel. If the engine doesn't sit level, yes, this can cause a few gremlins to say the least. The front to rear angle being off throws off the shift linkage- ie:bad rear mount. I've seen them pop out of gear from bad rear mount.
Old 02-21-2013, 03:09 PM
well the rear and driver mounts are both fairly new yonaka mounts. the tranny mount is the rigged up one that was on there when i got it. i ordered an ebay one to hold me until i get some more money
Old 02-21-2013, 03:10 PM
are u talking about the half shafT? i just put 3 new bolts in it today. not sure if it did anything. havent drove it and will drive it when new mount comes in
Old 02-21-2013, 03:44 PM
Sorry dude I guess it was confusing, but yes the "mid shaft, half shaft, intermediate shaft" if the bushing is bad, feels like unbalanced wheel. If engine is not level side to side, can cause bad vibrations and premature inner c/v joint wear, axle popping out. How "rigged" is the trans mount? Sounding like trans mount by description.
Old 02-21-2013, 04:14 PM
they took the auto mount and welded some metal and cut it to where the tranny sits lower. honestly it looks like that did a halfway decent job. heres what happened. i got the car. not too long ago i found out that the trans case was broke in the back. ive always heard the t bracket chattering but thought it was just the exhaust or something loose. finally went and got the exhaust welded and flex pipe added and still chatter from the back. so i checked it out and seen it had been broke. i looked at it and didnt see the bottom one broke as well only the top. a buddy of mine who has been into hondas alot longer than me told me to order the 99-00 si bracket because my tranny was a b16. so we switched out the bracket and before we did this the car was fine. except of course the shaking when i let off the throttle etc. because of the rear mount not being connected. after we switched out the brackets found out the bottom hole was also torn so we just kept the si bracket in there. we also replaced the driver side mount with the yonaka mount.. what im thinking is that we broke something while we was shifting the motor alot to change both of them. i put the original mount back in on the driver side and it still shook. just got a new rebuilt tranny so i can connect the rear mount and everythings connected now and its still shaking. not nearly as bad though.
short and sweet.. im thinking we had to break something while we was moving the motor around to get everything to line up because it was fine before. also i put the eg gsr bracket back on and got rid of the si. .. whew lol.. any help would be welcome.
Old 02-21-2013, 05:45 PM
Possible one of inner/outer c/v joints got screwed in the process along with half shaft bushing. I've had a bad carrier bearing(completely sheared off) in my diff before which can also cause bad vibrations in the drivetrain. So ya its prob drivetrain related.
Old 02-21-2013, 06:41 PM
Im not a fan of the welded motor mount idear.... put that conversion mount onm and see if it helps at all. My motor was snapping axles and thumping and shaking while driving until I put on my conversion mount from hasport (great company btw)
Old 02-21-2013, 07:50 PM
bbut it wwas shaking before and after the new tranny installation. isnt the drivetrain in the tranny? im new in the car scene and this is my 2nd honda. also how do i check the half shaft bushings?
Old 02-21-2013, 07:51 PM
also just put new driver side axle in.
Old 02-21-2013, 07:52 PM
could it be the rack? the passenger side boot is a lil messy on the rack.. lol
Old 02-21-2013, 08:38 PM
beecee18's Avatar
Driving like this must have been interesting to say the least
Old 02-21-2013, 08:54 PM
lol yeah it was "different".. no hard shifting and i couldnt ride 1st at all no matter what speed. other than that it wasnt that bad
Old 02-22-2013, 05:51 PM
beecee18's Avatar
Well it has damaged your car obviously.
Our cars cant be driven without the proper engine position without causing failure to your car or unsafe situation
Old 02-22-2013, 06:49 PM
The rack is most likely leaking or messy from inner c/v grease spinning out of the c/v boot. Drivetrain is any parts btween engine and wheels to transfer energy of flywheel/clutch into wheel rotation. Trans, axles, hubs etc.
93grayeg
10
04-02-2010 07:47 PM
fasterthenmost
31
11-21-2005 06:23 PM
Dyzee
03-16-2004 12:02 PM
yellowCRX6
01-29-2004 03:00 PM
Quick Reply: delsol/lsv swap is shaking
