DIY rear camber question?
I am about to do the DIY rear camber adjustment with the longer bolts and washers but i need to know what bolts are needed, specifically threadpitch and lengh. also how many bolts need to be used i did a search and someone said one washer for every inch lowered. Is this true and if so what thickness washers should i be using. Thanks for any help.
Re: DIY rear camber question? (Quad-Damge)
I picked up the washers at Home Depot, I forgot the size but they're fairly large like 1 1/2" overall and it worked great. Just make sure the bolt fits through. I also made sure they were both the same thickness. Re-install the stock bolts and get an allignment. It worked great. Good Luck.
Fuster_Cluck
07-10-2002 10:35 AM
Lei Siew Long
07-08-2002 06:11 PM
fcuked
10
05-08-2002 09:18 PM
