Stretched Head bolts.....
Re: Stretched Head bolts..... (jdm-spec-eg)
bolts could eventually snap, headgasket woudn't seal on the block right. don't be half assed and buy new ones y0!
Solbros Owns Me
Re: Stretched Head bolts..... (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin »</TD></TR><TR><TD CLASS="quote">bad seal between head and block.
engine wouldnt run.
dont reuse them more than once, get ARP headstuds.</TD></TR></TABLE>
I've re-used mine about 5 times in the past year...no problems
engine wouldnt run.
Solbros Owns Me
Re: Stretched Head bolts..... (BCRUZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BCRUZ »</TD></TR><TR><TD CLASS="quote">Emerika go knock on wood.</TD></TR></TABLE>
nope...lol
3 of the times were within 1 month of each other. I'm not about to buy new headbolts after 100 miles of drviing
nope...lol
Re: Stretched Head bolts..... (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika »</TD></TR><TR><TD CLASS="quote">
nope...lol
3 of the times were within 1 month of each other. I'm not about to buy new headbolts after 100 miles of drviing</TD></TR></TABLE>
but you torqued them once already. after that, its as good as recycle.
nope...lol
Im burning coolant in #1, #3, and #4 cylinders only when the engine gets hot. The motor was just rebuilt by myself. The head and block were decked, so I am to assume that it has to be the head bolts.
Its a B18C, with CTR pistons(.25oversized).
Thanks for your help guys!!!! I will be replacing another head gasket and a set of ARP head studs!!!
nope...lol
3 of the times were within 1 month of each other. I'm not about to buy new headbolts after 100 miles of drviing</TD></TR></TABLE>Ive reused mine: when i changed the headgasket; and then when i changed rings and bearings and head gasket Its not any high performance engine.
nope...lol
Re: Stretched Head bolts..... (b16a ferio)
Yeah I have too. This is the first time anything bad has ever happened with reusing the head bolts. I will let you guys know if this cures my problem!!
Thanks for all your help, guys!!
nope...lol
not saying its gonna happen, but if you keep reusing them they dont hold as well, its good to replace them EVERY time if you have money comming out the ***.
nope...lol
