98 civic/obd1 d16zc swap - starts with starting fluid then dies help
Old 05-21-2016, 11:18 PM
Fearz32's Avatar
Default 98 civic/obd1 d16zc swap - starts with starting fluid then dies help
1998 civic with obd1 d16zc running all obd2 sensors car was running
-new aeromotive fuel pump
-new fuel filter
-pump primes for 2 sec when key turned
-starts momentarily with starting fluid
-swapped main relays
im trying to get my hands on a FP gauge
any input is greatly apreciated
Old 05-22-2016, 02:23 AM
ClaytosTech's Avatar
Default re: 98 civic/obd1 d16zc swap - starts with starting fluid then dies help
If you swapped relays and the fuel system still does not run I would suspect a sensor issue. The most likely culprit is something like the crankshaft position sensor or the camshaft position sensor. Either of these could cause the computer to not run the fuel pump. This page has some good info on starting sensors. https://www.yourmechanic.com/article...-from-starting
It is sort of strange though that the pump primes but does not have enough fuel pressure to start on its own. Normally if the pump would prime it would start then die right away without the need for starting fluid.
Old 05-22-2016, 03:36 AM
mk378's Avatar
Best to measure with a gauge but another test you can do is disconnect the return line that goes from the fuel pressure regulator to the tank. Fuel should come out of the regulator when you turn the key on and prime. This is a better test than disconnecting a line at the filter since it proves the pressure from the pump is high enough to open the regulator. Use a stock fuel pressure regulator if you aren't already.
Old 05-22-2016, 07:29 AM
Former User's Avatar
Default Re: Car starts with starting fluid then dies help
Focus on the fuel injectors. Start by checking whether all 4 fuel injector clips get battery voltage with key in ON(II).
Old 05-23-2016, 09:27 PM
Fearz32's Avatar
Default Re: 98 civic/obd1 d16zc swap - starts with starting fluid then dies help
thanks guys it was a weak pump
MarknEthel
Honda Civic (2001 - 2005)
04-14-2017 07:09 AM
BIGef
20
09-13-2012 04:36 AM
CourtesyBullet
05-07-2008 12:24 PM
nicko360
15
01-17-2007 06:22 PM
inline4
10-29-2003 11:09 PM
Quick Reply: 98 civic/obd1 d16zc swap - starts with starting fluid then dies help
