DIY civic eg EX hatch restoration
#52
Re: DIY civic eg EX hatch restoration
Thanks mate it took me 09 hours to clean up the car completely from inside out .... and you are absolutely right that sand cleaning was a tough job though
#54
Engine dismantle and ready for cleaning Rod bearings slight indication of polish fading while main bearings
polish faded ... I guess i have to measure the size of the bearings dia internal and external ... crank polish is required only i guess...
#56
Use this link
https://honda-tech.com/forums/honda-...tures-3051143/
Be organized with your bolts. I'm ocd about internal engine bolts going back to the same spot they came from.
#57
For what its worth I usually pull apart a motor at 280k miles if it leaks out of both sides of the motor, and of the 8 cars ive done that with, I have never seen a motor with so much sludge build up. A normal block has a golden stain
#58
OP lives in the middle east - maybe it has something to do with the climate?
#59
#60
Use this link
Thanks mate i will surely keep it considered
#61
Use this link
and i marked the bolts already
#62
Cleaning process is going slow and steady ..... fed up with cleaning and rubbing..... that **** dirt with oil and sand ... combined together and stayed there for about 15 years
is never goin a give up that easily ........ using 91 unleaded fuel only to rub and scrubbing .... used some brake parts and engine cleaning fluids nothing worked for it
Trust me it took me about 56 hrs to clean only these parts .......
Block has been polished and found out to be bored till 75.40 mm ... It was using stock P2CY piston
Crank has been polished and still on standard size mains and rods both are ok and good
Yet to clean .... Intake manifold complete rip a part , Block bare bone, head bare bone and the transmission in the end.
#64
#66
some parts are really in bad shape and need replacement but here in this part of the world those parts are not available ...
Thermostat assembly and its body and the pipe.
#69
Those pipes are just for the coolant to flow through it. You're in a warm climate (right?), so if I were you I would just leave the water lines disconnected from the IACV. It will function the same without them.
#71
#72
Keep it original to reduce potential issues on start up.
You are converting a carbed car to a 97 harness so I would just make everything like original and modify later
#75
Buddy thats not true ..... i am using D15Z4 complete engine which has been dismantle completely bit by bit ...
