Distributor Cap Help
Old Feb 18, 2012 | 09:51 AM
Agguhnitus's Avatar
Icon3 Distributor Cap Help
I have an EG6 with a B16a2 swap. Over the past weeks I have noticed a leak and I couldn't figure it out until today. It's coming from the bottom of my distributor cap. I dont know what this means. Does this mean that I may need to replace it? Please help. thanks!
Old Feb 18, 2012 | 10:11 AM
crappyhatch's Avatar
Default Re: Distributor Cap Help
Its not your distributor cap leaking. I would look over your cam seals real good, I would bet thats where the leak is coming from. Its a pretty common issue.
LSVTAK_EK's Avatar
I would guess that its the camshaft holder plate thats leaking not distributer.
Old Feb 18, 2012 | 10:58 AM
Agguhnitus's Avatar
I have scheduled a tunning and an overall inspection of the engine up in Tacoma on the first weekend of March. Is this issue something I need to take car of now or something that I can have the shop (Speedfactory) do for me when they look at my car?
Old Feb 18, 2012 | 11:36 AM
motegicivic's Avatar
Are you talking about oil coming from the cap itself? so if take off the cap it is wet?
Or are you talking about where the distributor housing meets the engine?
Old Feb 18, 2012 | 12:16 PM
EsotericImage's Avatar
Retired Moderator
This
If it has oil inside, then youll need a bew distrib. If its under the distrib, might just need the o-ring replaced
Old Feb 18, 2012 | 12:44 PM
apexi_rsx's Avatar
replace the O-ring or smear some rtv around the o-ring and put it back on it will seal it as well.
Old Feb 18, 2012 | 01:01 PM
LSVTAK_EK's Avatar
either way its not something to cause any huge concern untill you bring it in as long as its functioning properly. I would monitor it closely tho! gl
Old Feb 18, 2012 | 01:06 PM
Agguhnitus's Avatar
The oil leak is where the distributor housing meets the engine and it is at the bottom of the cap.
Old Feb 18, 2012 | 03:45 PM
Easy to do, mark the distributor, remove it, there is a 2 dollar o ring pull it off and carefully replace it put back on.
There are write ups on here, search it.
You can let it go but it will start to get messy.
Old Feb 18, 2012 | 03:56 PM
98civdx's Avatar
Master Detailer
Originally Posted by EsotericImage
This
There is another O ring inside it, you don't have to replace the whole thing.
Pull the cap off and see if it's wet inside.
yangkm
Feb 26, 2011 04:20 PM
F22 Accord
Oct 28, 2010 07:28 AM
jchrm80
May 17, 2009 09:27 AM
tca0bell
Oct 18, 2006 04:16 PM
Mike1486
Aug 26, 2004 08:58 AM
