Directions on how to change brake pads
Ok I know its proboly not that hard but its like 20 degrees here so I dont wanna be out there in the cold figuring out what to do so if you could give me a run down and the steps to change 96 dx brake pads that would be great. Thanks
Re: Directions on how to change brake pads (LOWLIFEHATCH)
Here's a suggestion, don't change anything when it's that cold out. Things are more brittle and prone to breaking, unless you plan on heating up the area.
Loosen lug nuts on both wheels
*Run inside and thaw
Jack up car and put on jack stands.
Remove caliper reatining bolt and brake line bolt. 10mm I believe.
Do the other side
Remove old pads on both sides, they slide out in the middle.
Open the hood and remove the brake fluid res. cap.
Get a clamp and a piece of wood. Put the wood over the brake piston and use the clamp to push it all the way into the caliper.
Now do the other side.
Now, while inside, get the pads ready and go and place them in the caliper the way you took out the old pads.
Do the other side.
Now, place the caliper back over the disk making sure the pads go around the disk (not that hard you cannot get the caliper on unless they are)
Bolt it back onto the mount, along with the brake line.
Do the other side, same as above.
Mount wheels back on and hand tighten lugs.
Lower car off of jack stands.
Tighten lug nuts in a star pattern.
Test drive later.
Do the other side
Do the other side.
Test drive later.
Re: Directions on how to change brake pads (Spade)
Thanks alot.... I wish i didnt have to do it tomm but there like no pad now and they starting to make noise tonight
Shawn
Re: Directions on how to change brake pads (shawnhayes)
I don't recall having to remove that before. Do you have to? (been a long time since I got rid of those piece of **** Akebono calipers and upgraded to the Nissin's.)
Shawn
Shawn
No I just do it so I can set the Caliper on the suspensio without worries of a tweaked brake line.
Shawn
Ok I just did my rear discs this past weekend. I am a newbie too and I had a hard time figuring out but I got it. First, just jack your car up like normal. Take off whatever side tires you're doing. Then, take off the heatshield if its covering the two bolts holding the caliper to the arm. Next, use a 14mm socket and remove the two bolts holding the caliper in place. After you take out the two bolts gently with a screw driver (try not to scratch the rotor), pry the caliper apart and the brake pads should fall out. Next, properly place the brake pads where they should go. Then you are going to have to push the piston back into the bore. Mine was a big *** cross looking thing so I used a big *** screw driver to push it back in. You might want to use a C CLAMP for this. After it's pushed back in you will then replace the new pads to where the old pads were. Put the caliper over the brake pads. Put the two 14mm bolts back into the caliper and screw them on. Screw the heatshield back on too if you took that off. Put the tires on, and you're good to go.
Re: Directions on how to change brake pads (psychotic)
Rear discs on the Civic/Integra must be "screwed" in by using a screwdriver or a special Honda tool. If you just "push" them in without rotating them in properly, you can ruin the piston/parking brake.
Shawn
tru dat... we did that wit a car in our autoshop. But we hate the teacher so we prolly did it on purpose. The omni had no friggin engine and is scratched by every student in shop for like that last 10 years.
E-brake or Handbrake
54
10-11-2004 03:02 PM
bpetruzzo
09-01-2004 02:55 PM
