Difference between B16A & B16B head
recently i have changed the b16B head....im a little bit confused with the head stamp...it stamped year 92..and code with pr3-1...few of my friends says it ITR not CTR....on the left of the head its marked B16B....need your advise asap
Re: Difference between B16A & B16B head (chaqier77)
ITR/GSR is a B18C stamp
LS non-Vtec is B18B
B16, and B16A, B16A1, B16A2 are the only B16 codes I'm aware of, maybe I'm out of the loop?
After doing a quick google seach *which you should have done* it looks like its probably a B16A CTR head
LS non-Vtec is B18B
* B A N N E D *
ITR's aren't 1.6L so they wouldn't have a B16B head. B16B is a Civic Type R motor so you have a CTR head. As far as the difference between the two I honestly don't know maybe another member can answer that for you.
Re: Difference between B16A & B16B head (spivt11)
Thanx guys for your info....do you know the code pr-3?if im not mistaken the b16B head not stamp with 'B16B' on the head.I have one on the left of my engine head.
Cool Cool Island Breezes. BOY-EE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chaqier77 »</TD></TR><TR><TD CLASS="quote">recently i have changed the b16B head....im a little bit confused with the head stamp...it stamped year 92..and code with pr3-1...few of my friends says it ITR not CTR....on the left of the head its marked B16B....need your advise asap</TD></TR></TABLE>
Since the B16B came around in 97, I'd say it's not a B16B head. The ITR came around in 96. So not an ITR head either.
The ITR/CTR/B16A share a head casting. There is a green stamping on the back of the CTR/ITR head.
The bare head is pretty much identical.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spivt11 »</TD></TR><TR><TD CLASS="quote">ITR's aren't 1.6L so they wouldn't have a B16B head. B16B is a Civic Type R motor so you have a CTR head. As far as the difference between the two I honestly don't know maybe another member can answer that for you. </TD></TR></TABLE>
Read above.
Read above.
Re: Difference between B16A & B16B head (B serious)
the only difference between the pr-*1-4* B16B head and the pr-*1-4* B16A head is the cams are a little larger in the B16B,also has some minor port work done to them at the factory, and I THINK hallow intake valves to that save on weight
90B16aCRXsi
12-13-2007 07:12 PM
Wafler
14
01-20-2004 05:28 PM
SuPeR_MaN
12
09-14-2002 06:19 PM
