did swap motor wont start
I did a d series swap...i stayed with de series bc i plan to boost it soon...I did the swap from a d16z6 to a d16zc (JDM)....IT acts like it wants to turn over but it wont...i went through and cleaned the grounds to the tranny/valve cover/thermostat housing...I also have fuel and i have spark...i just put new plugs in...Is there any other grounds that i should check? I purchased the motor from Hmotorsonline.com...Any ideas?? Maybe the firing order is off?
Re: did swap motor wont start (JDM-SI Sol)
The firing order is 1342.
#1 cylinder on the engine is at the right/driver side, next is #2 and so on.
#1 on the distributor cap should be at the nine o'clock position, when looking down at the top of the cap. The direction of rotation is clockwise
i fixxed the firing order and it started...now it runs like ****...it acts like it is missing a cylinder or a vacume line is off...the idle is high and enstable...when you give it gas the car about quits....any ideas?
Re: (eg-owns you)
i took off the IAC and it was just black in the valves...no big chunks of anything or nothing big....any idea on how to clean it?
markz95.4dr
31
01-15-2012 12:58 PM
phoboyjimmy
10-14-2002 08:38 AM
