DELSOL with b series swap linkage Q
* B A N N E D *
Re: DELSOL with b series swap linkage Q (ReDRoCkEt)
well i kno for sure that i can use the dohc vtec linkage from a delsol.. i wated to kno if i can use the integra linkage
* B A N N E D *
Re: DELSOL with b series swap linkage Q (ShowTymers619)
which exactly do i need from the picture.. i kno .. 13 and 14 is there anything else i need like the little misc. stuff . is there and stuff i can use from my exsisting linkage?
Aside from the DOHC sol linkage, youll need to get 31,17,15,22,18. The rest of the hardware you can use from your current linkage.
Modified by moto27cm at 8:25 AM 4/30/2004
Re: (amy del sol)
inline4 sells them... i think $200 w/ energy suspension bushings.
http://www.inlinefour.com/hondelsolvte.html
You looked at the REFERENCE numbers and they were the same. hondaautomotiveparts.com gives ref numbers, not part numbers.
Go to http://www.slhondaparts.com for real OE part numbers.
you can use the integra linkage (DC) you just have to extend both shafts about an inch and a half, i ran into this problem in the middle of a swap it sucked, for me and for the guy i was doing the swap for...i just took it to a muffler shop and told them i needed a bit more then an inch on the linkage they cut welded it i went back finished the swap and the linkage worked perfectly (install the linkage on ur setup to make sure the length u need, in my setup only a bit more then an inch was needed)...spend 20 bucks at a muffler shop not 200 on new linkage
* B A N N E D *
Re: (moto27cm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moto27cm »</TD></TR><TR><TD CLASS="quote">You looked at the REFERENCE numbers and they were the same. hondaautomotiveparts.com gives ref numbers, not part numbers.
Go to http://www.slhondaparts.com for real OE part numbers.</TD></TR></TABLE>
i tried that it doesnt show the part number it ses its unavailble
Re: (ShowTymers619)
SI
54301-SR2-A02 EXTENSION, CHANGE $69.53
54201-SR2-A03 ROD, GEARSHIFT $43.82
VTEC
54301-SR2-G01 EXTENSION, CHANGE $75.65
54201-SR2-G03 ROD, GEARSHIFT $43.82
VTEC
Re: (moto27cm)
Integra linkage WILL NOT FIT a del Sol w/ a B-Series swap!
So much misinformation it's sad...
Like the poster above said... Integra linkage is over an inch too short.
MBlake55
06-07-2008 11:44 PM
vntperformance
03-26-2002 06:19 AM
opusONE
02-01-2002 04:10 AM
93civic_b18b1
08-27-2001 02:09 PM
