Del sol turbo timer help me plz
I got a 93 delsol si d16z6 boosted. I got a apexi turbo timer for free and want to hook it up. I made an attempt to wire it according to the only how to post I can find and it was for a 94 civic. But it didn't work. Does anyone know wat wires from the ignition I need to tap into? I don't plan on using the o2 sensor reading bc I have a wide band. It's the silver model with red numbers. I have the manual and know the wires on the timer side just need to know them on car side if u can help that would be great. Or even where to get a jumper harness. Thanks
Re: Del sol turbo timer help me plz
you'd have better luck in the "Fourced induction" section. over here:https://honda-tech.com/forums/forced-induction-16/
You would have much better luck getting a harness adapter. They're cheap, and they make it so you don't have to cut anything. Search - they're out there.
If u still need help let me know i can help.
I wire up all kindas of things. But yea i got a hks timer and wiring it to keep the car running but radio off.
Use the spades @ the fuse box and igniton wire fron the key switch.
xbonesyx
04-05-2007 03:48 PM
TURBO LS HATCH
03-07-2003 05:32 AM
MugenHonda
11-04-2002 12:38 PM
