VTEC issues
VTEC issues
I have a 95 Civic 2 door coupe. i am a first time honda owner. have a couple friends who are fairly knowledgeable with hondas though. It had a PO6 when i first bought it and a non vtec wiring harness. the engine is a D16z6 bottom end with a y8 head and a TD-42u distributor. we wired the vtec accordingly and i put a P28 in. the car does run better and stronger with the new ECU but it doesnt seem that my VTEC is working. Any help would be appreciated. Thanks in advance
Re: VTEC issues
Yes I can take it to the redline. And no there are no codes. The ECU I have came out of an automatic I have a 5 speed. The only codes are for the parking lock which is code 19 and for the o2 sensor which is 41
Re: VTEC issues
Take it on a back road, get it into second gear at regular driving speed (i.e. 15-20 mph at approx. 3000 rpm, idk). Then mash the pedal to the floor. Listen for the engine to get louder, and feel for a sort of stronger pull (although these are SOHC VTECs, they don't seem to pull as hard without that exhaust VTEC that the DOHCs have). Then come back here and give us a heads up of what's going on. A video might be helpful too if you can manage it.
Re: VTEC issues
No clue for vtec and redlining normally means ots working.
But to fix your auto lockup code desolder the resistor in the ecu. I think its r18 and r17 needs a jumper. I dont remember its been a while.
And second pop the valve cover off and look toake sure all bolts are there.
I had the vtec bolt come lose and oil wasnt locking the rockers.
Also understand vtec on a d16 isnt the same as a b16 or b18.
stevil_knevil
10-26-2008 04:55 PM
