Del sol trunk floor/lining dimensions
Re: Del sol trunk floor/lining dimensions
Probably the foam pieces that stick under the board.
I was thinking maybe cutting one out of plastic or something that doesn't absorb water
Measurements are in millimeters(mm) obviously, could change it to inches if needed
Yes these 3 rectangles are places where to glue foam spacers and the round ones are holes for OEM plastic clips. I could add some notes to it.
I made mine some years ago from moisture resistant plywood and it holds good. Even fixing leaks there are lot of condensation moisture as the large trunk lid catches moisture and water drips. The cabin ventilation for DelSol is poor.
typac69
12-06-2008 09:25 AM
hermanssol
01-26-2008 05:42 PM
