del sol obd2 swap
del sol obd2 swap
I bought a 94 del sol S and its an automatic , the engine im putting in is a b16b ctr . Will i be able to just remove the existing harness and replace it with the obd2 harness that is used with my CTR? or will i run in to some issues with the dash harness ETC ET
Advice is appreciated !
Technical Hero
Re: del sol obd2 swap
The harness is RHD and one piece. Your best bet is to use your harness and add the necessary wiring alterations.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/92-00-honda-engine-swap-wiring-guide-vtec-non-vtec-2987229/
Seagull Management
Either run OBD1 injectors (you can reuse the D-series ones), alternator and distributor or Use an OBD2 integra engine harness with an OBD1 chipped and tuned ECU, or use a conversion harness and the OEM CTR ECU. All of this assumes the car is being converted to a manual.
https://honda-tech.com/forums/showthread.php?t=2987229
Edit: or would i need to use a jumper harness and chip my P06 thats already in it or buy a pre chipped one?
Technical Hero
It's still a one piece harness. You could swap over and solder the connections for the alternator and distributor from your CTR harness onto your del sol harness. Then reuse your del sol injectors. If you ran a chipped p06 you would only then have to wire up VTEC and be done with it.
Eg5ir1
07-20-2013 06:58 PM
SIR_APPROVED
12-18-2009 06:59 PM
killerB16A
01-16-2007 11:01 AM
