del sol ls o2 sensor ?
my buddy has a 93 sol si with a b18, running obd1.
just bought a new catback for it and running into some confusion...
so, his original engine, z6, should only have 1 o2 sensor.
currently there are two, one on the header before the cat and one after the cat (i believe this port was not there originally, but drilled at a later date by a previous owner).
now, obd2's run 2, one before and after, but his has always been obd1, so it shouldnt be there.
his header only has 1 port for an o2 sensor, but im also pretty sure that an obd1 b series runs 2 o2's, both on the header.
so, should he grab a header with 2 ports (one on the ex man part and one right before the cat) or would he be okay running only 1?
Seagull Management
Re: del sol ls o2 sensor ?
In all OBD1 setups there will be 1 O2 sensor before the cat.
Don't feel like threadjacking but are all obd1 o2 sensors the same???
IE... can I take a o2 sensor lets say from a 96 dodge neon and use it... or do they read different car to car...
There are universal fit Denso O2 sensors online that are cheap compared to OE application sensors. I think all 4 wire sensors are the same for Hondas in this era. The one I got for a GSR was a Denso "first time fit" part number 234-4209.
Anyway, you only need one sensor. Some headers have two bungs to let you run a wide band or work with different motors. I know I've seen the O2 mounted close to the engine side of exhaust manifold and also on the catalytic converter side.
Civic Racer X 7
14
05-01-2011 09:55 AM
gtowni3
04-09-2005 09:09 PM
