del sol hub question
when i pull the wheel off my car and try to spin the hub its really hard to spin. is this normal? i thought it was supposed to spin pretty easily. its on a 1994 del sol s
Re: del sol hub question
my bad... it is both front hubs. on a 1994 manual del sol. i just replaced the axles so there ruled out. could it be a wheel bearing? i dont here any scratchy noises or anything usually heard with a bad wheel bearing
you realize that brake pads are touching the brake disc surface most of the time right?
put the wheel back on and spin it.
you will hear numming noise when driving or crackling/ louder humming when turning if your bearing goes dry or damaged.
i had mine go out and it was very niticeable.
ahloung
Northern California (Sales)
03-12-2006 09:41 PM
