del sol fog lights
del sol fog lights
how do u turn them on??
and any one know of a place where i can get a quarter panel for cheap went to honda and they have them for 530
Re: del sol fog lights (eg831)
pics might help and the year of your car also
there is usually a button in the center of the center consol just behind the ebrak handle if you have the oem button.. if it is on another type of switch it might be a little harder to find but it should be atleast in plain sight..
EDIT:
WOOPS.. I WAS THINKING PARKING POLE.. BOTH FRONT AND REAR FOGS ARE ON THE SWITCHES ON TOP OF THE CLUSTER
ps. crazi_E is wack
EDIT2:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazi_E »</TD></TR><TR><TD CLASS="quote">again your terribly wrong, del sols dont have a spot for switches by the e-brake</TD></TR></TABLE>
ORLY?? well explain wut those are in front and behind the ebrake??
Modified by wonderB at 12:42 PM 3/28/2008
EDIT:
ps. crazi_E is wack
EDIT2:
Re: del sol fog lights (wonderB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wonderB »</TD></TR><TR><TD CLASS="quote">pics might help and the year of your car also
there is usually a button in the center of the center consol just behind the ebrak handle if you have the oem button.. if it is on another type of switch it might be a little harder to find but it should be atleast in plain sight..</TD></TR></TABLE>
you couldn't be more wrong
the button should be on the top peice of the cluster..i believe its the one all the way to
the left
the left
Re: del sol fog lights (leroyb)
They wont turn on if you dont have the headlights on either, try that and if that doesn't work then check your bulbs. And go to certifit for the fender, they have them for around 80 bucks i believe.
yes there is a write up on it https://honda-tech.com/zerothread?id=817274 doese that help?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wonderB »</TD></TR><TR><TD CLASS="quote">WOOPS.. I WAS THINKING PARKING POLE.. BOTH FRONT AND REAR FOGS ARE ON THE SWITCHES ON TOP OF THE CLUSTER
ps. crazi_E is the man
Modified by wonderB at 2:12 PM 3/27/2008</TD></TR></TABLE>
again your terribly wrong, the rear fog switch isnt located on top of the cluster
Modified by crazi_E at 4:55 PM 3/28/2008
flippedoutasian
12-11-2003 08:17 PM
