del sol door lock problem
ok when i get out of the sol, i lock the door normally, it seems like it locks. but when i close the door i can still open it. the only way it stays locked is if i use the key after its closed...wtf?
Re: del sol door lock problem (Bcuz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bcuz »</TD></TR><TR><TD CLASS="quote">I do believe you have to hold you inside door handle open then push to lock it, then let go off the inside handle then cose it.</TD></TR></TABLE>
yes i know, as it is on all hondas...........
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bcuz »</TD></TR><TR><TD CLASS="quote">Well whats the problem then?
If you know soo much take your door panel off and see if something came loose.</TD></TR></TABLE>
if i knew what the problem was i wouldnt be asking....anyway...like i said, it seems like it works right. the lock wont flip if u dont pull the handle just like it should, and it flips fine when u do. but then the door still opens
Re: del sol door lock problem (JDM96SpecCTR)
Try taking your door panel off and removing your weather plastic/sound dampener. Get a light and look around inside the door at all the coonections. There are these plastic holse with a clip, pole goes in the hole, lol, then the clip clicks into place. Sometimes, these bust because there made of the worlds cheapest plastic (cost efficient to honda). Try that and keep posting cuz.
yea imma try that...i had a problem like that on my ek, the pole kept popping out of the lil plastic clip and the hole, and i coulndt open the door from inside
Dude I've been there you actually have to role down the window, and get out like a dipshit, I know it sucks.
Those clips can be bought anywhere to fit it. Maybe 50 cents a piece or something like that.
fast6fan
01-17-2018 11:36 AM
toben
02-24-2007 08:05 PM
drunknmonkey18
04-07-2005 05:38 AM
japspecjohn
20
08-24-2004 06:10 PM
