Del Sol A/C Question
Re: Del Sol A/C Question (jgold47)
yes you can if you have the spot on your crankshaft pully, if you do get any 92-95 civic AC system...
Also check out http://www.solsociety.com fo rmore info
You will have to find all the lines, evap coil, condensor coil and fan, and a/c compressor. I dont know if the r134 compressor will work, it should though. Yoour car is a 93 and it was the r12 year.
No USDM Del Sol came with factory A/C, it was a dealer installed option.
I don't believe any model or model year was excluded from the option, so you should be able to install it yourself - provided you have the right parts for your model year & model.
r.etheridge
05-09-2011 04:14 PM
Del Sol Russell
09-05-2006 05:14 PM
