a/c compressor 1 from a civic 1 from a del sol, are they the interchangeable?
Old 05-03-2011, 07:12 AM
r.etheridge's Avatar
Default a/c compressor 1 from a civic 1 from a del sol, are they the interchangeable?
Got a ac compressor from a 94 civic DX or CX (not 100% sure which one) and one out of a 93 del sol S model. Are these compressors the same? I can look up the #'s on the civic when I get home and go to storage to find the del sol compressor. just wondering if someone on here knew if they were interchangeable. It would save me some time, no telling where the del sol one is in my storage building. Thanks in advance.
Old 05-04-2011, 09:12 AM
Default Re: a/c compressor 1 from a civic 1 from a del sol, are they the interchangeable?
ok so this is what #'s I got off of each
-del sol compressor- TRF090: Model 2050: honda p# 38800-P06-A01
-civic dx/cx compressor- TRS090: Model 3057: honda p# 38800-P06-A02
they are close but not right on. The holes that the lines go in are in the exact spots and the compressors are visually identical so I think it may work, just wanted a second opinion.
Old 05-04-2011, 09:32 AM
Seagull Management
94EG8's Avatar
'92 - '93 Used R12 refrigerant, '94+ use R134a. They're different. Get a '94+ compressor for a Civic/Del Sol/CR-V.
Old 05-05-2011, 01:40 AM
I thought you could convert everything to 134-a?
Old 05-09-2011, 01:53 AM
Old 05-09-2011, 05:22 AM
Seagull Management
94EG8's Avatar
You can but It wont cool like a proper R134a setup.
Old 05-09-2011, 06:46 AM
Just needed to know if it would work. I dont have the $$ to get a R134-A compressor and I have a perfectly good one off a 93 del sol sitting in the garage thats free so im going to go with it. Thanks for your help
Old 05-09-2011, 06:53 AM
Seagull Management
94EG8's Avatar
I never said it would work, you can convert an complete R12 setup to R134a, but you're going to run into issues with what you're trying to do. Oils are different IIRC, and I could be wrong but the two lines that connect to the compressor may not bolt up either.
Old 05-09-2011, 04:14 PM
well im going to give it a try, im not really trying to sink anymore money into this DD than I already have.
April Ramirez
10-30-2018 09:26 PM
adamman11
08-10-2016 10:23 AM
Del Sol Russell
09-05-2006 05:14 PM
jgold47
03-09-2006 06:50 PM
Quick Reply: a/c compressor 1 from a civic 1 from a del sol, are they the interchangeable?
