Del Sol Brake Specs?!
Ok, I have a 1993 del Sol S. It has really bad brakes so I was thinking of doing the rear disc swap. I came across a 1993 wrecked del Sol Si with rear discs. I worked out an arrangement to get pretty much whatever I want (or what is left). I am going to take the entire rear assembly including sway bar. Should I bother with the fronts or is it the same size? Also what about the proportioning valve and/or Master Cyl? I'm going to grab the power rack just cause...
Can you think of anything else suspension wise that would be worth upgrading from S to Si?
-ryan
-ryan
gmcuajo1
06-22-2014 07:23 AM
310HPS2k
10
03-13-2009 05:45 PM
