DC2 rear sway bar into an ek?!?!?!?
alright well i got a 99 civic CX i recently put in Si front lower control arms and a CTR sway bar...but now i want to do the back and was wondering if GSR or Ls rear sway bar would bolt right up to my hatch???
Re: DC2 rear sway bar into an ek?!?!?!?
Yep, but for a proper fit you'll need 99-00 civic si brackets that bolt to the rear subframe or use the GSR brackets with a spacer on the top bolts...when you see them it'll be self explanatory. GSR rear bars are a couple of mm's bigger than the LS I believe.
i just bought some BLOX LCA'S it wouldnt make a difference right?
mmmm not the braket is a metal peice that connects the frame to you u-shaped metal piece. I did it in my Ej1 and was a bitch to find out what i was missing... let me look for a pic of what i looks like one sec
k so check thi sout...
is part#30 in the pic below
Here is the link of a thread i have in a different forum where i was inquiring about this. Keep in mind that this is for 92-95 civic. But im sure the 96-00 civic follows the same path just with different part number.
Thread: http://s14.zetaboards.com/EJ1_Owners...6579664/1/#new
JLEK
11
07-27-2007 06:24 PM
Amuse9
12-30-2002 12:48 PM
