dang! my ek died tonight. auto motor needed IL/WI/MI/IW/ Midwest?
Re: dang! my ek died tonight. auto motor needed IL/WI/MI/IW/ Midwest? (Jhonny Ricer)
i cleaned the engine bay good with some degreaser i got at autozone. wiped off the excess water/moisture and slammed the hood to let her dry. came back out after about ten minutes and it wasn't running. I tried to restart and it barely idles with my foot on the gas. its fucked, i should have left it dirty. =/
i have been having overheating issues lately as well. i guess it was a matter of time.
she was my 100+ miles a day ride to work. i'm screwed.
Re: dang! my ek died tonight. auto motor needed IL/WI/MI/IW/ Midwest? (43!)
i dont think you killed your engine with water and degreaser unless you were spraying it in your intake.
Re: dang! my ek died tonight. auto motor needed IL/WI/MI/IW/ Midwest? (ridin98civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridin98civic »</TD></TR><TR><TD CLASS="quote">i dont think you killed your engine with water and degreaser unless you were spraying it in your intake.</TD></TR></TABLE>
It's running so rough now though. I'm going to try again in the AM =/
check to see if there is water in the spark plug tubes, check your plugs, check your cap and rotor (i have seen water in a dist. cap), was it running while you were washing it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridin98civic »</TD></TR><TR><TD CLASS="quote">check to see if there is water in the spark plug tubes, check your plugs, check your cap and rotor (i have seen water in a dist. cap), was it running while you were washing it?</TD></TR></TABLE>
once it drys it will be ok
I can't believe you would be capable of replacing the motor if you think getting the **** wet then it running like crap means you need a new motor
fitbmx86
05-13-2007 10:10 AM
