D16Z7 2 O2 sensors
D16Z7 2 O2 sensors
are there two O2 sensors on the D16Z7. gotta a friend with an LX that just had a 98 ex engine put into his car. looked up the specs of the 98 ex and it says it comes with a D16Z7 motor. guessing because its OBD2 maybe thats the reason for the 2 O2 sensors?
Re: D16Z7 2 O2 sensors (DSeriesBKilla)
this site must be wrong then http://www.geocities.com/chipm....html
Re: D16Z7 2 O2 sensors (StrikerX)
ok found it, its D16Y8 and is obd2, question is if the header has only the secondary O2 sensor mount that is under the engine, were would we fabricate a hole to mount the primary O2 sensor. its for a DC sport 4:2:1 one piece header.
You can drill a hole and tap it for another o2 sensor, I think another way is to wire the first o2 to the second so it will not throw a CEL but I think the car might not run right cause it reads the difference between the 2 sensors.
aaronblake98
02-15-2004 04:20 PM
Hatebreed215
03-09-2003 08:11 PM
