d16z6 turbo... wont start need help asap pleazz!!
Just swapped d16z6 with turbo everythin is installed and hooked up. I started the car it ran for about 3 min till it warmed up. then died.. and now wont start. any suggestions??
Re: d16z6 turbo... wont start need help asap pleazz!!
not gettin any spark anymore.. changed cap and rotor still no spark. distr. bad?? doesnt make sense ran till it warmed up now nothin.. any reasons why im still not gettin spark?
Any CEL codes?
With the key in ON(II), is there battery voltage on the Blk/Yel wire attached to the coil and igniter unit in the distributor? If so, test the coil and igniter unit.
Common issue with Hondas running, than immediately going to a no-start, is the ICM inside the dizzy. Ron is on the right path.
That's where I would look first.
Thats what i checked yesterday and that was it ignition module and i just went ahead and changed out the coil too. started right up. thanks.
