D16Z6 Trannie Converson Question
Whats up, i have a 92 4door 1.5 vtec d16z6 its a auto, i want to change it to a 5 speed but i dont know where to look and what kind of stuff i will need and how much it will cost. any help is appericated
Re: D16Z6 Trannie Converson Question (BlackHonda)
I believe you need:
-5 speed tranny w/ clutch assembly
-shift linkage
-clutch pedal assembly
-cluch master cylinder/ fliud resivour
-slave cylinder
-hydrauic hardline from master to rubber flexline to hardline to slave cylinder w/ brackets and clips
-5spd ecu or modify your original ecu
I think thats it in terms of what you need
Modified by UNCW08 at 7:46 PM 10/22/2006
-shift linkage
-slave cylinder
Re: (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense »</TD></TR><TR><TD CLASS="quote">just don't put the AT flywheel bolts on the MT flywheel</TD></TR></TABLE>
is there a diffrence?
Re: (Sleepy_Red_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch »</TD></TR><TR><TD CLASS="quote">is there a diffrence?</TD></TR></TABLE>
yep the manual ones are longer and don't have the letters at on the heads
Re: D16Z6 Trannie Converson Question (UNCW08)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNCW08 »</TD></TR><TR><TD CLASS="quote">I believe you need:
-5 speed tranny
-shift linkage
-slave cylinder
You will also need the hasport auto to manual mount. can't use stock 5 speed mount on auto chassis.
-5 speed tranny
-shift linkage
-slave cylinder
Re: D16Z6 Trannie Converson Question (Hybrid93Eg)
Oh yeah, check out the H-T classifieds to piece together what you need or check to see if someone has a wrecked car that maybe able to supply the parts you need in a little package deal or go to a auto recycling yard to pick up parts. Go to a recycling yard to the hard hydro line since they do bend and kink and my be damaged in shipping.
95 honda8
07-29-2007 05:33 PM
SiKDeLSoL
04-14-2003 08:43 PM
