d16z6 power steering sensor?
Old 04-11-2009, 03:31 PM
Bradsxx7's Avatar
Default d16z6 power steering sensor?
did a manual to power steering swap.
Where does the sensor plug in? got the clip with loose wire ends.
do i ned to connect the sensor?
or not needed?
thank you.
Old 04-11-2009, 03:36 PM
Murk 'EM's Avatar
Default Re: d16z6 power steering sensor?
a power steering sensor? ware are you talking about on the pump?
Old 04-11-2009, 03:45 PM
Bradsxx7's Avatar
on the line from the pump to the rack. 2 wire plug.
Old 04-11-2009, 04:42 PM
Bradsxx7's Avatar
Power Steering Pressure Switch (PSPS)
The power steering oil pressure switch is attached to the power steering high-pressure tube and detects a power steering load. When a power steering load is detected, it signals the ECM. The ECM adjusts the idle speed for the increased load.
I found this online so i can leave it unhooked right?? and just give gas when turning the wheel and not rolling. lol idk .
Old 04-11-2009, 09:49 PM
Davus's Avatar
Sounds fine to me. I did the opposite when I swapped from power to manual rack, just kinda clipped the connector and didn't throw a CEL or anything. You don't even have to give it more gas I'd guess. If it puts a load on the pump, EFI should take notice and give a bit higher idle.
Old 04-12-2009, 12:20 AM
NastyHabitzCRX's Avatar
no pump, no load on the motor, no worries to leave unplugged!
Old 04-12-2009, 02:36 PM
Bradsxx7's Avatar
but i have a pump, and a load on the motor, so i am worried.
thanks for the input.
HypL
08-01-2016 05:55 PM
clewis152
08-07-2012 05:01 PM
Fred Demara
01-04-2012 04:33 AM
__oversea
07-21-2008 05:14 PM
ahron
07-18-2007 03:50 PM
Quick Reply: d16z6 power steering sensor?
