d16z6 Intake Manifold on d15b8???
I was wondering if you could put a d16z6 intake manifold on a d15b8 engine since the d15b8 manifold and throttle body are really small and the d16z6 are a little bigger. Has anybody done this or tried this??Is it possible??
No Sales Forums
Re: d16z6 Intake Manifold on d15b8??? (red_hatchback)
yes it will bolt up, but the motor it's self is so i'm not sure your'e going to get much of a gain if any at all.
its possible......i threw a z6 IM on my old d16y7 motor....works fine...all you need is a d15b8 intank manifold gasket....
Re: d16z6 Intake Manifold on d15b8??? (ef9turbohatch)
hey also is it possible to install a dohc throttle body on the d16z6 intake manifold if so what mods do you have to do or is it a straight bolt on? also which dohc throttle body is the biggest (b18c,b18a,b18b,b16,etc..)
yes. Port match is a good idea, tho.
https://honda-tech.com/zerothread?id=525764
https://honda-tech.com/zerothread?id=466550
https://honda-tech.com/zerothread?id=786867
IMO i like http://www.edelbrock.com/autom....html.
Re: d16z6 Intake Manifold on d15b8??? (B16aDasher)
so the best throttle body to get is the b18c5-62mm Throttle body. I'll take that in mind. I'll just port the intake manifold to be the same as the throttle body. Thanks
danmej1
10-11-2009 09:41 AM
