d16z6 to b16a swap
Old 08-24-2007, 11:57 PM
projectpd's Avatar
Default d16z6 to b16a swap
Ok here i go ! were puttin a b16 in a 93 hatch SI . is there a difference between a p28 pinout and a p30 pinout ! im wondering for vtec ? will the stock wiring harness in a si be able to work a b16 ? i know we gotta run a knock sensor ( i think ) if yes wich pin is it on the ecu connector ? i looked on the forum but couldent find anything ! And is there anything else we gotta do ? the motor is in the car now we just gotta wire it right !! thanks alot everyone that reads my topic !
Old 08-25-2007, 06:22 AM
pkdog167's Avatar
Default Re: d16z6 to b16a swap (projectpd)
I'm not sure, but shouldn't you be asking this question before you do the swap?
Old 08-25-2007, 07:14 AM
egsleepercivic's Avatar
D3 is the knock sensor on the ecu plug
Old 08-25-2007, 09:13 AM
X93siX's Avatar
you use the stock wiriing harness and use the p30 ecu...
you can use the p28 but it wont run right...
Old 08-25-2007, 09:17 AM
crazyguy's Avatar
i just did the exact same swap as u are going to do soon.i did a d16z6 to b16a jdm sir 2 swap.everything is plug and play and fits perfectly, but because my b16a swap comes with complete engine harness and they are all uncut.so i dont need to run any hanrness..the ecu harness too.but they are both obd1.and i use a p30 ecu that comes with the swap.and if u want to use your p28 ecu, it has to be chipped in order to be running perfect with b16a swap.
Old 08-25-2007, 10:56 AM
big-cat's Avatar
Default Re: d16z6 to b16a swap (crazyguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy &raquo;</TD></TR><TR><TD CLASS="quote">i just did the exact same swap as u are going to do soon.i did a d16z6 to b16a jdm sir 2 swap.everything is plug and play and fits perfectly, but because my b16a swap comes with complete engine harness and they are all uncut.so i dont need to run any hanrness..the ecu harness too.but they are both obd1.and i use a p30 ecu that comes with the swap.and if u want to use your p28 ecu, it has to be chipped in order to be running perfect with b16a swap.</TD></TR></TABLE>
this guy did the swap the way it should be done but either the p30 or p28 is fine but if you have the p28 you might as well just take it to a place to get chipped and then get your b16 tuned as well.
Glowicki
20
10-08-2013 04:26 AM
Bipolarcivic
08-09-2011 12:43 PM
Rok_Stok
12
03-01-2009 02:37 PM
crazyguy
06-04-2007 05:33 PM
hatch b16a guy
12-21-2005 10:20 AM
Quick Reply: d16z6 to b16a swap
