D16y8 Valves.
D16y8 Valves.
Are they auto adjusting or do you have to set them. Just wondering i had an extra y8 head apart and couldnt figure it out...
-x m d
-x m d
Re: D16y8 Valves. (xmd)
you need to adjust them your self because i just had to have my valves adjusted when i did my timing belt swap and i watched the guy do it. He had to keep sliding a metal sheet inbetween something near the valve spring to check the gap.
Are you talking about adjusting the valve clearance? You have to do that manually. Here is how to do it on an 8 valve d15b8, but it's kind of the same on the D16Y8, just with 16 valves. http://pub161.ezboard.com/fbse...topic
Re: D16y8 Valves. (ramz7887)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ramz7887 »</TD></TR><TR><TD CLASS="quote">you need to adjust them your self because i just had to have my valves adjusted when i did my timing belt swap and i watched the guy do it. He had to keep sliding a metal sheet inbetween something near the valve spring to check the gap.</TD></TR></TABLE>
The "metal sheet" is called a feeler guage.
New User
Let me offer a couple of tips.
I found that not all valves needed to be adjusted when I did mine. Check them first and you can save a bunch of time.
Instead of turning the crank with a socket, I just lifted the driver side of the car just till the tire is off the ground. Put the car in 5th gear. Now you can turn the wheel and that will turn the crank. Easier than the method recommended on the manual.
If you can’t get HONDABOND just get the Black RTV sealer it works great I have used it several times without any problems.
Also taking out the Spark plugs will make it easier to turn over.
Have fun.
Have fun.
im a monster hehe
06-25-2007 07:31 AM
