D16y7 idle problem
D16y7 idle problem
Hi,
latelly I had some problems with my d16y7 96 civic coupe.
http://www.youtube.com/watch?v=f277w...ature=youtu.be
The car does this strange noise when idling with warm engine and only when its not moving (stoped for red light etc.). So i.e. when going on a road with neutral gear and rpm on the idle, there is no noise what so ever, but once you stop you from time to time get this.
I cleaned the intake and the IACV, which made the problem to be occouring not that often. I also ajusted the idle a little, which also made the problem less evident. But I start to feel that I should look also somewhere else.
When I did open the hood and listen to the engine itself, there were no strange noises what so ever, but inside the car I get this.
Any ideas?
Thanks.
Any ideas?
Thanks.
Re: D16y7 idle problem
I was thinking it might be running just on 3 cylinders but it doesnt sound like it... and if it did so, it would be doing this noise also when going on neutral gear...
Ill try to do the compression test next week, thanks zoepmp.
MyEj1Broke
01-10-2014 08:09 AM
Nisif
11-26-2011 07:22 PM
greenzchatch
07-29-2010 02:14 PM
2000civicsi
10
10-26-2005 04:05 PM
