D16Y7 idle adjustment screw? Where!
Old 02-26-2008, 11:23 AM
Civic Racer X 7's Avatar
Default D16Y7 idle adjustment screw? Where!
usually its located on the side of the TB for the Z6 and Y8
I just got this 2000 Civic Hatch and the idle is really high
I popped the hood and looked around the TB and didnt see it anywhere
is it on the back?
do I have to remove the air cleaner assembly to gain access to it?
Old 02-26-2008, 11:44 AM
blk92_d16's Avatar
On my friend's Y7, it was hiding behind a rubber romment or something...but it's still on the TB, passenger side.
Old 02-26-2008, 12:14 PM
Banned
vannak_5415's Avatar
Default Re: D16Y7 idle adjustment screw? Where! (Civic Racer X 7)
so you have a Y7? its right there in front of the throttle body, with the green color, take you throttle body apart and clean it with carb cleaner, also inside your intake manifold. that should help too
Old 02-26-2008, 12:32 PM
well the adj screw is UNDER the black filter case facing DOWN
I cleaned the IACV while I was at it and i THINK i have it fixed
we'll see after some driving
Old 02-26-2008, 12:42 PM
Malakai's Avatar
Is it under the intake assembly(on the tb) under a little black rubber plug of sorts?
Old 02-26-2008, 12:55 PM
yep it faces down and is hidden under neathe the breather box on the back side of the TB
the IACV cleaning seems to have done it
my IACV didnt have screens tho
just 2 passageways weird
Leviatard
18
10-30-2014 09:28 AM
snatch
40
03-29-2011 01:25 PM
9311dan
03-04-2007 01:33 PM
greddy13
05-14-2006 08:04 PM
EGbeater
15
11-28-2003 02:03 PM
Quick Reply: D16Y7 idle adjustment screw? Where!
