Fuel cutoff
Old 12-29-2013, 03:57 PM
BIGef's Avatar
Default Fuel cutoff
I have a 97 civic coupe bone stock ebay turbo.
Ran good idle good.
Recently when we full throttle the car fuel cuts around 4k and up. The rpm will slowly climb up but loses a lot if power
Like its a rev limiter only happen on Wot
Regular driving it runs fine
Old 12-29-2013, 04:23 PM
I never narc'd on nobody!
NotARaCist's Avatar
Default Re: Fuel cutoff
Bone stock, no tune?
There's your problem. Get the car tuned, and stop being stupid. Do a little bit of research before you go bolting up power adders.
Old 12-29-2013, 04:25 PM
Shit Posts: 15
JDMswagSerf's Avatar
Lol
Any cel?
Only at wot. I would think bad tps....?
Old 12-29-2013, 04:46 PM
B_Swapped93's Avatar
"ebay turbo kit" there's your main issue ! stop being cheap and get legit parts. but as said get it tuned even better get a s300 and wideband so you actually know what's going on along with a boost gauge.
inb4turboblewupmyengine
Old 12-29-2013, 05:26 PM
dfanatic86's Avatar
You gotta pay to play. Simple
Old 12-30-2013, 12:08 AM
BIGef's Avatar
We are trying to tune it. But how when this rev limiter thing is coming up. It's just leaning out when looking at the wideband.
Just because it's an ebay turbo it isn't gonna go out that fast I know there junk. Of course later on upgrade to legit.
Old 12-30-2013, 01:16 AM
Technical Hero
HondaPartsHero's Avatar
What kind of wideband? Is it the autometer christmas light one? How are you trying to tune it? Stock ECU? Check engine light on?
Old 12-30-2013, 03:34 AM
NotARaCist's Avatar
How exactly are you trying to tune it? Do you have ANY idea what you're doing? What's happening is your car is not tuned at all, and your stock ECU is seeing a shitload of pressure on your stock MAP and freaking the **** out. Stop trying to drive the car, call Xenocron, and buy a socketted ECU and a basemap chip for your car. Use the basemap to drive it to a professional tuner.
Old 12-30-2013, 10:33 AM
crazyhouse2011's Avatar
Oh my god.... this thread.... so much fail in this thread...
You cannot run a turbo on a NA engine with a stock NA ECU.
Old 12-30-2013, 11:24 AM
carlos8's Avatar
What Engine Management?
Fuel pump?
Injectors?
Map sensor? How many psi are you trying to tune it?
Where's hooked your wideband?
Old 12-30-2013, 11:30 AM
Hysterically Calm
TomCat39's Avatar
Yeah my first thought was you put turbo on and didn't upgrade your injectors. Stock injectors won't be able to provide enough fuel for WOT turbo so even tuning it won't do much to fix the issue.
You have to up your injector size and chip your ecu and then tune it. Mo dollas masta... mo dollas!
Old 12-30-2013, 11:51 AM
95Sedan's Avatar
lol hopefully your have NOT detonated the car to the point of no return.
Happy schooling young one
jv88_dc2
02-04-2012 08:23 PM
KhanhCord
04-06-2010 11:24 PM
092eg6
01-03-2010 05:42 PM
92civichatchsir
02-24-2006 08:23 AM
MNTuner
12-09-2002 08:40 AM
Quick Reply: Fuel cutoff
