d16a6 head on a d16y7 block?
i know the head will bolt up, but do i use head bolts from the y7 or the a6 for the head? i'm not sure if they are diff or not i nkow that the z6 head on the y7 y8 block require longer head bolts for at least 2 of them. anything else i should know about? also is the stock cam from the y7 better than from the a6, in terms of performance?
[Modified by sohc_boy, 10:20 AM 8/10/2001]
New User
Re: d16a6 head on a d16y7 block? (sohc_boy)
Good question there man. I'd like to know too. SOHC tech is always fun. I would check out the hybrid board at http://hybrid.honda-perf.org
There's a few articles on there about the "Mini-me" and related SOHC swaps.. Good luck.
Re: d16a6 head on a d16y7 block? (accord55)
why bother? You should install a y8 head on your y7 block. It will flow better then the a6 and you will have vtec.
liam
liam
91dxhatchswaped
15
07-20-2004 08:55 PM
