d15b compression? what should it be, or at least what is decent
Old 05-22-2005, 04:07 PM
tarheeler's Avatar
Default d15b compression? what should it be, or at least what is decent
I have searched but did not find any post stating what "good"ompression numbers should be for a Civic DX with 16 valve d15b engine. I purchased a cheap compression guage and I am reading about 120psi on all 4 cylinders. Sounds low to me. I had a new head gasket, vavle job and pistons rings put in about 6 months ago.
Old 05-22-2005, 04:10 PM
mc
mc's Avatar
Default Re: d15b compression? what should it be, or at least what is decent (tarheeler)
seems kinda low are you sure you did the test right? did you hold the gas peddle all the way down
Old 05-22-2005, 04:17 PM
Kyles ej1's Avatar
Default Re: d15b compression? what should it be, or at least what is decent (mc)
its not always about compression, its consistancy. but that seems low to me 2, mybe u didnt do it right
Old 05-27-2005, 06:38 PM
Thrillhouse's Avatar
Default Re: d15b compression? what should it be, or at least what is decent (93ejay1)
Make sure the car is warmed up too
Old 05-28-2005, 06:10 AM
hogsnot's Avatar
Ok, I was not doing the check correctly. Now I am reading 150psi on all 4.
Boostn B20
11
11-27-2008 01:22 PM
Z32Z06
Honda S2000
02-08-2006 04:59 PM
CNSK
04-10-2005 08:54 AM
Btothe3rdDegree
11-14-2004 01:44 AM
GSR44
01-11-2002 09:58 AM
Quick Reply: d15b compression? what should it be, or at least what is decent
