d series water pump/timing belt ?
Re: d series water pump/timing belt ? (BauleyCivic)
well reason I asked....i got a used pump and timing belt for sohc vtec. dude didnt state what year...but I was under the impression 92-00 were the same as far as that went. I got the **** for 7.50 plus shipping with less than 8k on them. oem honda. so I was going to use them for the d15 whenever I get it...????i dunno still cheap
Risky Business
Re: d series water pump/timing belt ? (RedEK)
As far as timing belts are concerned:
D15B7, B1 = 106 teeth
D16Z6, D16Y7, D16Y8 = 104 teeth
D15Z1 = 103 teeth
About the water pumps, I dont know... from what motor are the parts from and what motor are you trying to put it on?
D15Z1 = 103 teeth
well he was saying sohc vtec. so im going to be under the assumption its for the z6/y8/7. it will get used by me or someone else so im not to worried about it I guess but just trying to find out those specs. thanks again bro
Re: d series water pump/timing belt ? (JdM_HoNda)
if your motor is still attached to the tranny and if it's still in the car, put the car on the ground with tires on and go in from the engine bay with a breaker bar and crack it loose.
if not they somehow keep the crank from spining and have some one hold the motor really good and break it loose with a breaker bar if you don't have a airtools.
and about waterpumps I believe that all 92-95 D series waterpumps were interchangable, but don't know about EKs. timing belts are different on different models. easy way to check is to compare part numbers.
Re: d series water pump/timing belt ? (ABK)
first of all i would neva buy those 2 things used. those are very critical parts to the engine.i wouldve just scaredp up some money and got those fresh from honda themselves. nicely packed in a box and sealed.
B18B1-Crx
12-04-2011 07:37 PM
cxjon
06-19-2005 07:08 AM
SC0TT
08-03-2002 04:44 PM
