D series tranny maiting with B series clutch
Old 05-06-2003, 08:36 AM
skribblah's Avatar
Default D series tranny maiting with B series clutch
if i have a D series motor and a B series flywhell and clutch, pressure plate etc, could i put the B series clutch on my D series with an 94 Si transmission?
Old 05-06-2003, 08:37 AM
AlphaQup's Avatar
Default Re: D series tranny maiting with B series clutch (skribblah)
thats what i need to know too
Old 05-06-2003, 08:38 AM
skribblah's Avatar
searrrrrrrrrrrrrrrrrrrrrrrrrrrch!!
lol jk, just getting rid of the obvious posts
Old 05-06-2003, 08:40 AM
RyanEJ8's Avatar
D and B is not interchangeable.
Old 05-06-2003, 08:42 AM
skribblah's Avatar
but this is the clutch and are you POSTIVE!!!
i know b & d not compatible dummy
Old 05-06-2003, 08:49 AM
senior gold member
Ivan's Avatar
Default Re: (skribblah)
umm please lay off the drugs. They're bad for you.
Old 05-06-2003, 08:51 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skribblah &raquo;</TD></TR><TR><TD CLASS="quote">
Then why did you ask?
Old 05-06-2003, 08:55 AM
Solbros Owns Me
Evs-One's Avatar
Default Re: (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">
Then why did you ask? </TD></TR></TABLE>
because some d series parts ARE interchangable with b series.
I don't think it will work because the input shaft on the b series tranny is larger than the d series input shaft....making it so the clutches will not be interchangable also
smnowell's Avatar
Default Re: (Ivan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ivan &raquo;</TD></TR><TR><TD CLASS="quote">umm please lay off the drugs. They're bad for you.</TD></TR></TABLE>
Couldn't agree more. Only thing that B and D have in common is they are both part of the english language. Other than that, they are very different. Biggest thing you will notice with the flywheels is the B-series crank uses 8 flywheel bolts to hold it on whereas the D-series flywheel is only held on by 6 bolts. That right there is going to be your biggest issue. Not to mention the tranny shaft that the clutch disc slides on to most likely had a different size/spline count. Basically, no, no it will not work at all....just go buy the right parts and sell your b-series stuff
Old 05-06-2003, 08:59 AM
Solbros Owns Me
Evs-One's Avatar
Default Re: (b16a ferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a ferio &raquo;</TD></TR><TR><TD CLASS="quote">
Couldn't agree more. Only thing that B and D have in common is they are both part of the english language. </TD></TR></TABLE>
throttle bodies are interchangable....as well as wiring harnesses... jm
Old 05-06-2003, 09:03 AM
cjames235's Avatar
Default Re: (Emerika)
i know the clutches wont work cus i tried to use my d clutch alignment tool to put on a b clutch and it wouldnt fit in the disc.
Old 05-06-2003, 09:06 AM
skribblah's Avatar
dam IT
thanks guys thos are the smart answers im looking for.
Old 05-06-2003, 09:14 AM
4g4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">
throttle bodies are interchangable....as well as wiring harnesses... jm</TD></TR></TABLE>
ADD:block and head sensors
Old 05-06-2003, 10:17 AM
dgonzals's Avatar
Location: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
d-series with d-series parts and b-series with b-series parts, no switching.....
jdm_vtec
06-18-2007 05:10 PM
Quick Reply: D series tranny maiting with B series clutch
