D series tranny maiting with B series clutch
1 Post
if i have a D series motor and a B series flywhell and clutch, pressure plate etc, could i put the B series clutch on my D series with an 94 Si transmission?
Re: (skribblah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skribblah »</TD></TR><TR><TD CLASS="quote">
i know b & d not compatible dummy
Then why did you ask?
Solbros Owns Me
Re: (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 »</TD></TR><TR><TD CLASS="quote">
Then why did you ask? </TD></TR></TABLE>
because some d series parts ARE interchangable with b series.
I don't think it will work because the input shaft on the b series tranny is larger than the d series input shaft....making it so the clutches will not be interchangable also
Re: (Ivan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ivan »</TD></TR><TR><TD CLASS="quote">umm please lay off the drugs. They're bad for you.</TD></TR></TABLE>
Couldn't agree more. Only thing that B and D have in common is they are both part of the english language. Other than that, they are very different. Biggest thing you will notice with the flywheels is the B-series crank uses 8 flywheel bolts to hold it on whereas the D-series flywheel is only held on by 6 bolts. That right there is going to be your biggest issue. Not to mention the tranny shaft that the clutch disc slides on to most likely had a different size/spline count. Basically, no, no it will not work at all....just go buy the right parts and sell your b-series stuff
Solbros Owns Me
Re: (b16a ferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a ferio »</TD></TR><TR><TD CLASS="quote">
Couldn't agree more. Only thing that B and D have in common is they are both part of the english language. </TD></TR></TABLE>
throttle bodies are interchangable....as well as wiring harnesses... jm
Re: (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika »</TD></TR><TR><TD CLASS="quote">
throttle bodies are interchangable....as well as wiring harnesses... jm</TD></TR></TABLE>
ADD:block and head sensors
jdm_vtec
06-18-2007 05:10 PM
