d series question..
d series question..
Hey i was wondering if i used an obd0 d series engine (head and long block) with an obd1 intake manifold and ecu would that work in a 95 civic? or is there any complications? just wondering thanks for any feedback
Re: d series question..
your dizzy and o2 sensor will be different....but other than that it should work. the main differences between obd0 and obd1 is the map and tps plugs and the o2 sensor i think. someone correct me if im wrong.
works, you just need a distributor conversion harness
to use MPFI i'm pretty sure you'll need to use an OBD1 ECU, so you'll need a conversion harness for that to.
http://www.phearable.net/shoppingcar...ness-p-35.html
http://www.phearable.net/shoppingcar...mper-p-75.html
(not sure about this second one)
EDIT: and yea, like he said, you'll have to do something about the O2 sensor
