d series Injectors Help!!!! ASAP
so im doing a turbo thingy on my d series and some one told me that when i hook my 440 blue tops up that they are going to fry as soon as i turn my motor over if this is true then what do i need to fix that
Re: d series Injectors Help!!!! ASAP (wish_i_was_h22a)
Depending on whether they are Peak and Hold or Saturated injectors, you may need a resistor box or you can just wire in a resistor to the injectors.
Re: d series Injectors Help!!!! ASAP (EX-T)
Blue tops run off of a resistor pack or resistor box. If you have one of those take it off before you go back to stock.
The resistor box is just a box that has a bunch of resistors in it that your injectors plug into. You can wire resistors inline with you injectors without the resistor box. The box just makes it look pretty.
